fluent multiphase mixture modal
Old   July 3, 2016, 05:10
Default fluent multiphase mixture modal
pawan
pawan1222 is on a distinguished road
hi,
i have done fluent multiphase by using mixture model to generate a solution for solid-liquid homogeneous mixture flow though a Al pipe but i didn't get the simulation properly i am trying to find axial and radial stress on wall with help of CFD simulation. Can anyone tell me how to put the bounary conditions where liquid as primary phase and SiC spheriacal solid grannual diameter 25e-06m secounary phase, laminar flow. homogenous mixture have constant pressure and constant velocity at inlet and at outlet 101325 pa. i want to vary a pressure an velocity at inlet to calculate different wall stress values.
pawan1222 is offline   Reply With Quote
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
to prepare a mixture of pulverised coal &air in fluent sukhvinder singh FLUENT 2 July 5, 2011 01:30
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 12:46
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 13:05
