FLUENT questions
Old   July 2, 2016, 18:31
Default FLUENT questions
Ferruccio Rossi
frossi is on a distinguished road
Hi all,
While I have some previous experience with CFX, I am completely new to FLUENT. So I would like to know if you guys could answer some of my questions:
1. In the General tab, what's the difference between "Pressure-based" and "Density-based" solvers?
2. In the General tab, what's the difference between "Absolute" and "Relative" velocity formulation?
3. What should I use for inlet boundary condition? "Pressure Far Field" or "inlet velocity"? What are the differences between the two? I am modeling flow on a wing.
4. what's the difference between standard and hybrid initialization?
5. What does the option "dynamic mesh" do?
6. Every time FLUENT solver completes a time step, a window pops up and makes a noise. Is it possible to suppress such behavior?
Thank you.
frossi is offline   Reply With Quote
boundary condition, fluent, inlet, outlet, wing
two questions about using the ANSYS Fluent liu_zh_w FLUENT 0 March 19, 2014 23:08
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
Simple fluent questions temp3733@gmail.com FLUENT 0 May 18, 2005 13:50
