DPM Segmentation Fault in UDF
Old   July 1, 2016, 04:21
Default DPM Segmentation Fault in UDF
JungHo Lee
jhlee9622 is on a distinguished road
Hello.
Now, I want to export the DPM data in a plane(particle velocity, particle location, particle id, particle time when particle is passing at each cell, and cell id which particle is passing).
For this, I've made a UDF code and it was compiled well in Fluent.
However, When I used this UDF in a Sample Trajectories, the message appears :
"Error: received a fatal signal (Segmentation fault).
Error Object: #f"
This error is captured and attached below.
This is the UDF code.
DEFINE_DPM_OUTPUT(PSI_C_method, header, fp, p, t, plane)
if(header)
par_fprintf_head(fp, " x y z u v w diameter mass_flow_rate time particle_ID ");
par_fprintf(fp, "%d \n", P_POS(p)[0], P_POS(p)[1], P_POS(p)[2], P_VEL(p)[0], P_VEL(p)[1], P_VEL(p)[2], P_DIAM(p), P_FLOW_RATE(p), P_TIME(p), p->part_id);
DPM is steady and no interaction.
Could any one help me, please?
Thank you.
jhlee9622 is offline   Reply With Quote
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
DPM UDF - Segmentation Violation & Stack Backtrace Prashanth Fluent UDF and Scheme Programming 4 July 10, 2012 11:39
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
So many questions in DPM & UDF - Help! URGENT! Prashanth FLUENT 0 March 3, 2009 23:26
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 10:02
