Rep Power: 18 ![]() |
I'd like to know whether a 0Pa pressure outlet boundary condition is correct for the following:
I'm modelling a flow through a sudden contraction: A rectangular box followed by a cylinder. Dimensions of the box are 1.7mx1.7x1.7 and the diameter of the cylinder is 0.165m and length 0.1m. Reynolds' number, based on the inlet flow rate (0.4m^3/s) and outlet diameter is about 1000. My turbulence model is K-omega with low Re correction. y+ <5 Problem: I'm finding flow does not develop properly in the pipe as it's so short. What should I do about the outlet condition? |
I'm comparing against experiment and there, the pipe is of that length.
![]() What do you think? |
Ok, maybe I can change the definition of my problem. So the end of the pipe is venting into the atmosphere and I'm interested in looking at how the length of the pipe affects the pressure inside the box. Do you see why I'm stuck with the specific length of pipe.
Perhaps I need to model a large box on the end of the pipe to represent the room in which I did the experiment? |
boundary condition, k omega, low reynolds number |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
replacing of shock tube high pressure part with a boundary condition for low pressure | immortality | Main CFD Forum | 0 | May 2, 2013 13:30 |
what boundary condition is proper for simulation of shock-tube low pressure part? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 2, 2013 13:22 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Pressure outlet boundary condition | fluent_newbie | FLUENT | 0 | December 1, 2011 23:51 |
