Help needed! How to continue with 2nd order calculations from 1st order solution? |
June 30, 2016, 12:29 |
Rep Power: 12 |
Hello everybody!
I really do hope i am not reposting a question or anything, but I haven't been able to find something regarding my case. I run time-steady simulations regarding a supersonic projectile. I have already aquired 1st order converged results but it is necessary that i proceed to 2nd order of accuracy in order to validate against archival data. I still haven't been able to understand how to initialiaze my 2nd order calculations from the 1st order converged solution. Please keep in mind that I set up my case on a remote location and then upload it to a computational cluster. Any ideas? Thank you in advance! |
July 1, 2016, 05:06 |
Rep Power: 12 |
You mean simply download the .cas file to my location, choose the "2nd order upwind", save the .cas, upload it to the same working directory as the 1st order converged .dat file and rerun the calculations?
July 1, 2016, 05:15 |
Rep Power: 12 |
Thank you very much! I will look into it!
1st order, 2nd order, convergence, initialize |
1st order vs 2nd order | ken | FLUENT | 8 | March 14, 2013 04:43 |
Limiters for 2nd order solvers | Heinz Wilkening | Main CFD Forum | 1 | March 14, 2013 04:40 |
2nd order divergence | Reg | FLUENT | 1 | May 17, 2005 04:08 |
1st order temporal & 2nd order spatial | Prateep Chatterjee | FLUENT | 0 | January 19, 2003 01:31 |
EULER-Forward-Method | freak | Main CFD Forum | 4 | June 12, 2001 10:19 |
