how can i solve this problem about divergence detected in AMG solver
Old   June 30, 2016, 06:09
Default how can i solve this problem about divergence detected in AMG solver
Philip Kim
bjkim87 is on a distinguished road
hello my name is philip kim.
i have some problems when i am trying to analysis fluid dynamics.
TUI messages is "Divergence detected in AMG solver : pressure coreection -> Turning off correction scaling"
i establish that model is k-e realizable, dynamic mesh was opened(transient solving), and solution method and controls, monitors are default values.
i have tried to change model but it was same.
how can i solve this problems?
i will wait for your responses.
thank you
bjkim87 is offline   Reply With Quote
Old   June 30, 2016, 06:23
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
thank you
what is your problem ?
define it and provide some picture
AHF is offline   Reply With Quote
Old   June 30, 2016, 22:07
Default how can i post a picture on your reply?
Philip Kim
i would like to post a picture on your reply. but i can't and dont know the way how to post it.
message is that
# Divergence detected in AMG solver: pressure correction -> Turning off correction scaling!
# Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps!
reversed flow in 146 faces on pressure-outlet 2.
Error at host: floating point exception
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2330 cells
Error at Node 0: floating point exception
Old   July 1, 2016, 05:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
check : mesh, boundary conditions, scaling/units, solver settings
Far is offline   Reply With Quote
Old   July 1, 2016, 07:03
divergence is on a distinguished road
Set your under-relaxation parameters to a lower level (especially momentum and turbulence). Also I would recommend checking that the flow is not disturbed in the mesh. What I mean with this is that sometimes there might be a surprising blockade for instance a interface might actually be defined as wall or maybe some volumes in your mesh are not completely connected into each other.
divergence is offline   Reply With Quote
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
EMMS drag model UDF NAD Fluent UDF and Scheme Programming 26 November 19, 2017 08:49
Error: Divergence detected in AMG solver: pressure correction wanna88 FLUENT 19 April 6, 2016 03:57
Divergence detected in AMG solver: pressure correction xinquanzhoucn FLUENT 5 July 21, 2014 05:49
Divergence detected in AMG solver: pressure coupled n.jithin.1991 FLUENT 6 January 5, 2014 12:43
