Natural convection with or without turbulence model
Old   June 30, 2016, 04:26
Default Natural convection with or without turbulence model
Christoph Ferk
chrisf90 is on a distinguished road
Hi everybody,
Im conducting some simple natural convection simulations: I am simulating a vertical channel 3,2m in height and 0,4m in width. Both sides have a fixed temperature of 313K and the air inlet temperature is 293K. density variation of air with respect to the temperature was modelled with the boussinesq approximation.
Hence the Ra-Number is about 5e10 which indicates turbulent flow. Therfore I implemented the k-e RNG turbulence model and refined the grid in the near wall region (highest y+ value is about 1,3). But the solution seems not reasoable for me. I expected the velocity to be zero in adequate distance to the wall, also the thermal boundary layer is pretty thick (see attachment). Calculated Nu-Numbers (Q*L)/(lambda*DetaT) are similar to analyticly calculated ones. So I am quite unsure what to think about this solution.
If I conduct the same problme without Turbulence model, the temperature and velocity field seem more relieable to me.
Any input would be highly appriciated.
Regards
Chris
chrisf90 is offline   Reply With Quote
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 03:47
Turbulence model for a natural circulation system raveesh FLUENT 0 September 23, 2014 04:11
Turbulence model for Natural circulation raveesh FLUENT 0 August 16, 2014 13:23
Boussinesq model for natural convection dreamz Main CFD Forum 3 October 8, 2013 14:10
How model natural convection in water? Fiska FLUENT 4 January 28, 2010 04:23
