June 28, 2016, 16:07 |
Disabling y-momentum equation
Shalabh Singh
Rep Power: 10 |
Hello, I am simulating mist-air flows over flat plate using Discrete Phase Model.
For a flow over a flat plate, both velocity v and it's derivatives are negligible and hence are of no use. Is there any way to switch off the y-momentum equation so that i can restrict any motion of air in the y direction? Please help me someone as it is causing a lot of problems. Thanks in advance. |
discrete phase model, momentum equation |
solving the momentum equation in UEqn. | callahance | OpenFOAM | 2 | October 18, 2012 10:38 |
Coefficients discretized momentum equation | michujo | Main CFD Forum | 4 | June 20, 2012 02:33 |
Discretization of momentum equation query | siw | CFX | 0 | June 20, 2011 09:38 |
What is the Boussinesq Term in Momentum Equation | CFDtoy | Main CFD Forum | 0 | August 11, 2008 10:56 |
Derivation of k-e model from momentum equation | CFDtoy | Main CFD Forum | 5 | May 10, 2006 17:53 |
