output data transfer from fluent
Old   June 28, 2016, 08:31
Default output data transfer from fluent
metu43331
metu43331 is on a distinguished road
I am new to ansys fluent. I will perform many analysis in fluent and I want to create a database. My problem is that I need to transfer output dataset automatically from fluent to my database.(database program can be anything but I want to use Mysql)
ıs there a way to do that? I
metu43331 is offline   Reply With Quote
Old   June 28, 2016, 09:09
Onur Özcan
oozcan is on a distinguished road
you can look up DOE (Design of experiments)
oozcan is offline   Reply With Quote
Old   June 28, 2016, 10:48
metu43331
I don't get the relation between DOE and my problem. can you explain more detailed.
Old   June 28, 2016, 11:15
Onur Özcan
I havent use it however reviewing about what it means, you might as well check and read about it
Old   June 29, 2016, 02:45
metu43331
I searched about DOE and I think it is not about my problem,what I understand is DOE is an evaluation of the effects of the inputs. my problem is not about that. I want to export my outputs from fluent to database dynamically. I may achieve this just use copy paste after every analys but I will perform so many anlys therefore it is not useful.
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Fluent Tutorial on Heat transfer Far FLUENT 15 July 29, 2017 16:31
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Fluent crash on writing data file after thousand iterations Chuck87 FLUENT 0 September 2, 2015 17:17
Structured Data Output Tristan Collins FLUENT 0 March 22, 2005 08:12
