Continous flow over the domain - boundary conditions
Old   June 25, 2016, 14:31
Default Continous flow over the domain - boundary conditions
Rafał Pilaczyński
pylaczynski is on a distinguished road
Hello everyone!
I have a simulation to make about flow over the domain. It is simple 2D rectangle domain with dimensions of 320x240 milimeters with 1 inlet and 1 outlet. I know what is the desired mass flow rate at the outlet and since it should be the continous flow it would be the same as the mass flow rate at the inlet.
When I am giving boundary conditions like this:
  • Inlet - mass flow inlet with mass flow Q_m=0,000273 kg/s
  • Outlet - pressure outlet with target mass flow of 0,000273 kg/s
I get very low values of velocity near the inlet (3*10e-2, when I have calculated the desired mean velocity should be around 7,1 m/s at the inlet with diameter 5 mm and given target mass flow).
Is this the right way to handle this problem? Maybe - since I know what velocity should be at the inlet it is better to define inlet as Velocity-inlet?
I know what mean gauge pressure should be inside of the domain (around 2000 Pa)
pylaczynski is offline   Reply With Quote
boundary conditions, simple case
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Appropriate Boundary conditions for jet flow in open domain shrutidhara.123 FLUENT 0 August 5, 2014 11:27
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
