Velocity profile export doubt!!
Old   June 25, 2016, 09:38
Talking Velocity profile export doubt!!
Abhinand
Abhinand is on a distinguished road
Hi guys,
I have a small doubt regarding exporting of velocity profile and importing it to another mesh for simulation.
Consider i need to export the velocity profile at the outlet of model1
I need to import to the inlet of model2
Is it necessary to have the x y z coordinates of the outlet of model1 to be same as the inlet of model2??
Secondly can u guys please tell what are the considerations and pre requisites to be fulfilled while exporting a profile from one model and importing it to another model??
Any help would be appreciated..
thanks
Abhinand is offline   Reply With Quote
Old   July 29, 2016, 14:41
Polytimi Sofotasiou
Polysf is on a distinguished road
Once exporting the Velocity Magnitude profile from one plane, you need to import it and select as inlet boundary condition the Velocity Magnitude.
However, because the cells take the velocity magnitude value of the nearest cell, then the mesh of the exported plane need to match the mesh of the new inlet plane.
If there is an error for any reason "you can open your first case, write an .ip file (File > Interpolate > Write data) and then read it for the new one (File > Interpolate > Read)."
Found from an older member.
Read this as well:
https://www.sharcnet.ca/Software/Ans...rof_using.html
But this didn't work for me and what I had to do was to export the profile and adapt the coordinates in excel, cause I knew exactly which were the x,y,z of the old and new mesh....
Polysf is offline   Reply With Quote
exporting profile, importing profile, profile data
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
Velocity profile interpolation FLUENT Mustafa1986 FLUENT 3 April 28, 2015 04:23
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 19:57
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
