Thesis help: Wave-drag reduction using passive flow method |
June 24, 2016, 03:31 |
Abhishek Gajare
Rep Power: 10 |
I am beginning to work toward my thesis, on a subject related to shock-wave/boundary layer interaction and wave-drag reduction using passive flow method.
Objective: To try and see the effect of introducing a passive flow (through a channel connecting the high-pressure to the low-pressure region, downstream & upstream of the normal shock wave resp. in a transonic flow) on wave drag reduction. The airfoil chosen is the NACA0012. Can anybody help me as to how to go about it? |
boundary layer control, shock wave, transonic flow, wave drag |
Drag force coefficient too low for a flow past cylinder at Re= 1e05 | Scabbard | STAR-CCM+ | 2 | June 5, 2020 14:44 |
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low | Scabbard | Main CFD Forum | 21 | June 19, 2018 13:58 |
2 Phase Flow, Gas Jet into Water Simulation Method | im_lenny | OpenFOAM | 3 | May 4, 2017 03:20 |
Drag Predication Problem for free-surface flow using STAR-CCM+ | naimishharpal | STAR-CCM+ | 11 | February 14, 2012 11:32 |
Causes for Drag over prediction in 2D flow | josip76 | FLUENT | 1 | September 20, 2011 09:18 |
