Axisymmetric space problem
Old   June 23, 2016, 15:21
Default Axisymmetric space problem
Abhinand
Abhinand is on a distinguished road
Hi guys...
I am creating a simulation for the modelling of swirl flows from a axial swirl burner.
For modelling the flow outside the burner(after coming out of the nozzle), I am facing a problem. I am using 2d simulation for the modelling off the outer regime.
I am exporting the velocity profile from the burner and importing it to the new domain.
What are the conditions necessary for exporting the profile??
Should the xyz coordinates at the exit of the burner and the xyz coordinates of the domain needed to be created be the same??
and what type of profile should i choose
Line profile or surface profile if im exporting to a 2d simulation?
Secondly i tried using a line profile and when i click axisymmetric it gives error
Invalid axisymmetric mesh with nodes lying below x axis.
Funny thing that the mesh quality i had used in planar 2d space was 1.00
Now when i changed to axisymmetric the quality is now coming as 0
Im totally confused. Please guide me
Abhinand is offline   Reply With Quote
axisymmetric 2d fluent, exporting data, swirl dominated flow
Axisymmetric Vs 2D Flow problem nikhil FLUENT 0 March 30, 2010 00:52
question about the volume integral in axisymmetric problem Renold FLUENT 0 December 7, 2009 12:28
2D Axisymmetric Problem sameer FLUENT 1 March 4, 2006 05:43
axisymmetric problem ahourri FLUENT 0 November 18, 2004 22:29
Scheme stack space problem calvin FLUENT 0 July 19, 2004 21:53
