Divergence in non-Newtonian fluid UDF
Old   June 23, 2016, 12:30
Default Divergence in non-Newtonian fluid UDF
mohsen
moabdi is on a distinguished road
Hi
I have written an UDF for a non-Newtonian fluid. first, i run the project with steady and constant viscosity for 10 iteration and after that i hooked the UDF but i faced with this divergence error:
# Divergence detected in AMG solver: epsilon -> Increasing relaxation sweeps!
# You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t)
turbulent viscosity limited to viscosity ratio of 1.000000e+20 in 249582 cells
reversed flow in 1614 faces on pressure-outlet 13.
Error at host: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error at Node 4: floating point exception
Error: floating point exception
Error Object: #f
UDF is:
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
#if !RP_NODE
real SR=C_STRAIN_RATE_MAG(c,t);
real n=0.70;
real k=0.00103;
real PV=0.0001;
real YP=2.8728;
real YSR=0.018;
real EV;
real SS;
SS=k*exp(n*log(SR));
EV=(SS/SR)+k*(exp((1-n)*log(SR/YSR)));
return EV;
#endif
now, what should i do for fix that ERROR.
it's my pleasure if somebody could help me.
thanks
BEST REGARDS
moabdi is offline   Reply With Quote
Physics of an incompressible fluid Jonas Holdeman Main CFD Forum 87 April 22, 2019 11:40
Drag Force UDF in Non-Newtonian (powerlaw) Fluid ali hemmati Fluent UDF and Scheme Programming 2 March 28, 2019 14:08
Fluid force in UDF linh nguyen Fluent UDF and Scheme Programming 0 May 21, 2014 09:02
Multiphase and Non Newtonian fluid wanna88 FLUENT 0 May 27, 2013 01:09
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
