Enabling turbulence dispersion force using TUI
Old   June 21, 2016, 13:23
Default Enabling turbulence dispersion force using TUI
Kimia is on a distinguished road
Hi all,
I want to use TUI for enabling the turbulence dispersion force according to Boiling tutorial. It is said to use the command below, but each time I get "invalid command" because of "yes" at the end. I'll be grateful if some one tells me how to write this command correctly.
/defi ne/models/viscous/multiphase-turbulence/multiphase-options yes
Kimia is offline   Reply With Quote
Old   October 15, 2017, 10:34
jimmy_84 is on a distinguished road
Hi
did you find the answer your question?
jimmy_84 is offline   Reply With Quote
Old   April 1, 2020, 06:53
Steven He
steven311 is on a distinguished road
did you solve this problem?thanks
steven311 is offline   Reply With Quote
Old   April 1, 2020, 07:23
Default TUI Commands
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The order of the commands changes from version to version and based on the context and chosen models. So, this is not same for everyone. Recommended is to type the command one at a time in Fluent and then observe what Fluent expects.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 24, 2010 00:56
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 08:07
pressure force and viscous force CFD FLUENT 0 March 7, 2006 02:03
