Temperature limited to 1.000000e+00
Old   June 18, 2016, 22:10
Question Temperature limited to 1.000000e+00
XH
xh110120 is on a distinguished road
Dear everyone,
I recently calculated the laminar flame of H2/O2 and the detailed chemical mechanism was used (21 steps). The mesh size is 0.1 mm, the time step is 1e-8s and the courant number is 2. At the very beginning, the residual curve is very nice. It can decrease by two orders in every time step after 5 iterations. However, after a while, with the propagation of the flame front, "temperature limited to 1e0" occurs and then "pressure limited to 1e0" also occurs. Obviously the pressure decrease is caused by the temperature decrease. But I don't know why such error would occur and how can I corrct it? The contours of mesh, pressure and temperature when this error occurs are attached here. Please help me! Thank you very much!
xh110120 is offline   Reply With Quote
Old   June 20, 2016, 20:04
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I think you need more refinement of your mesh
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 20, 2016, 21:33
XH
Thank you for your suggestion. However, I think 0.1 mm is small enough. Anyway, I'll try to refine it to see the results.
Old   June 21, 2016, 00:37
diamondx's Avatar
Ghazlani M. Ali
Mind sharing you case file ???
Regards,
Ali
Old   June 21, 2016, 04:22
XH
I'm sorry that one of my colleagues did't permit to upload the case file. I'll try to refine it. If it doesn't work, I'll ask for uploading such file. Sorry again.
chemical reaction, temperature limited
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
Temperature limited to error cstebbings FLUENT 0 April 1, 2014 18:45
Maximum Temperature limited malfrienz STAR-CCM+ 3 July 15, 2013 08:57
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 11:02
Temperature, Pressure Limited + numerical error Michael P Main CFD Forum 4 August 3, 2007 13:00
