June 16, 2016, 06:16 |
Flow equations convergence
Akhil H G
I have a model with a helical twist of 10 turns inside a pipe and I'm trying to simulate the flow of water inside this pipe under uniform heat flux conditions.
But my flow equations in the residuals graph are not converging even at 10000 iterations. My mesh orthogonal quality : 0.157 Aspect ratio : 36.78 Can anyone suggest ideas to solve this? |
June 23, 2016, 07:29 |
Sarang
Rep Power: 13 |
I am giving some general ideas or approach. hope this will help. Decrease under relaxation parameters that will help in convergence. Check mass imbalance in the systems. It should not be more than 2-3 % of your inlet mass in system. First solve for flow variables then switch to energy equation. New version of fluent starts from second order discretization, change it to first order and then change it back to desired order. Try to feed relevant turbulence parameters than default one. -Sarang |
convergence, fluent, mesh quality, pipe flow, twisted tape |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
mass flow convergence on interfaces | Tatiana | STAR-CCM+ | 0 | June 25, 2009 04:19 |
Weak rotational flow - Convergence Problems | Daggemann | FLUENT | 1 | May 8, 2009 10:45 |
Convergence for inviscid flow over sylinder | Rjakk | Main CFD Forum | 2 | March 21, 2007 11:53 |
