Divergence detected in AMG solver: pressure correction
Old   June 13, 2016, 07:08
Default Divergence detected in AMG solver: pressure correction
Chaitanya
CMICT is on a distinguished road
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 2: floating point exception
Primitive Error at Node 3: floating point exception
Primitive Error at Node 4: floating point exception
Error: floating point exception
Error Object: #f
after reaching close to the phase-2 temperature, it is showing above error
Can anyone guide me as to what might be the cause of this error?
Many thanks in advance
CMICT is offline   Reply With Quote
Old   June 14, 2016, 11:03
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Error Object: #f
More information is needed to give any suggestion. Explain your case briefly leading to the error.
-BB
bhargavbharathan is offline   Reply With Quote
Old   June 14, 2016, 12:49
Chaitanya
Actually I am carrying out my cfd simulation on tube boiling. water is flowing through tube. I have selected RPI wall boiling model. when temperature of the primary phase(water-liquid) reaches near to the temperature of the secondary phase(water vapour) this error has appeared.
Old   June 14, 2016, 12:59
Bhargav Bharathan
I have personally not done boiling before but, have you looked at the boiling model tutorial? Also, did you try to give temperature dependent properties to the fluid since specific heat and thermal conductivity keep changing with temperature.
Also try to reduce the URFs and increase them back after the residuals stabilize.
-BB
Old   June 14, 2016, 13:08
Chaitanya
Thank u for your suggestions.
floating point exception, pressure correction
Divergence detected in AMG solver: ads-0 Patrino FLUENT 6 May 12, 2022 04:11
Divergence detected in AMG solver: pressure correction emlejeen FLUENT 5 December 15, 2016 00:47
Error: Divergence detected in AMG solver: pressure correction wanna88 FLUENT 19 April 6, 2016 03:57
Divergence detected in AMG solver: pressure coupled n.jithin.1991 FLUENT 6 January 5, 2014 12:43
Divergence detected in AMG solver tiankongasd FLUENT 2 March 28, 2013 13:34
