Air tank filling
Old   June 9, 2016, 00:48
Default Air tank filling
gsr_132 is on a distinguished road
I am trying to simulate flow of air form a tank into another tank. There is only one flu8id involved i.e air. Source tank is of 30 litres in volume and at 6.5 bar pressure and other tank is of 385 cc in volume. it is transient simulation to understand the pressure rise in the smaller tank during flow.
This cannot be solved using VoF as the fluids are miscible and thus I was going for patching technique where I will patch the initial conditions to the bigger tank.
Kindly provide your valuable inputs for the methodology to be adopted.
gsr_132 is offline   Reply With Quote
Old   June 10, 2016, 04:16
On going for patch option with 6.5 bar pressure and then simulating the run, I am getting pressure results of very low magnitude like 0.5 Pa. It seems this is not working as expected.
Kindly let me know how to solve the same.
compressibleInterFoam case – a flat wall air cavity filling up with water Zeppo OpenFOAM Running, Solving & CFD 0 October 3, 2015 11:01
Tank refuelling simulation Bisht STAR-CCM+ 4 July 30, 2015 12:02
FLUENT-falling water in a tank filled with air Benjie FLUENT 0 October 7, 2013 04:39
Simulating air injecting to water in a tank? Howard Wang FLOW-3D 3 March 13, 2009 15:28
Filling a tank or pipe stu CFX 3 May 24, 2007 19:23
