Stuck Loading Initial Solution Data
Old   June 8, 2016, 17:55
Default Stuck Loading Initial Solution Data
Matt Acker
mattacker is on a distinguished road
I have currently upgraded to ANSYS workbench 17.1 and use fluent through workbench. I would like to use the design points to estimate a parameter but when I try to update my design points workbench just sits ther loading the initial solution data. I believe that the link may be broken in the software but I am unable to find where I can fix it in the options. Has anyone been having the same problem as me? Is there a simple way to fix it?
mattacker is offline   Reply With Quote
Old   July 15, 2016, 07:48
Paul Palladium
Fauster is on a distinguished road
Same problem....
Fauster is offline   Reply With Quote
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 02:42
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
