Exporting fluent solution
Old   June 7, 2016, 06:07
Default Exporting fluent solution
Viktor
Je5u5 is on a distinguished road
Hello
Is there a away to export fluent solution to a transient flow field to another fluent simulation?
the collision model i want to use canot work together with the dynamic mesh that creating the flow field.
i was thinking if its possible to take the solution of the dynamic mesh simulation and use it in another simulation without dynamic mesh and with particles and particle collision model?
or is there an other way of getting thigs done?
Thank you.
Viktor
Je5u5 is offline   Reply With Quote
transient solution de laval nozzle fluent ikrash FLUENT 0 July 6, 2015 18:18
How to avoid Fluent taking a different solution path? ansys_matt FLUENT 4 August 27, 2014 12:02
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
exporting data from Fluent in batch mode without exporting entire design point nnvoro FLUENT 5 May 6, 2013 02:51
