Multiply viscous dissipation with some constant in energy equation in fluent.
Old   June 3, 2016, 03:34
Default Multiply viscous dissipation with some constant in energy equation in fluent.
Alex Skerhut
alexskerhut is on a distinguished road
Hey!!
I need to multiply viscous dissipation term with a factor of 0.4( or say is as efficiency factor) and the resulting term should be further used as effective viscous dissipation term in further numerical calculations in fluent.
I searched a lot but could not find a way to implement this in fluent whereas several research papers that I am referring have implemented this in fluent.
Kindly help me in implementing this in fluent. Help will be highly appreciated.
Thanks
alexskerhut is offline   Reply With Quote
Old   June 7, 2016, 16:06
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Originally Posted by alexskerhut View Post
Hey!!
Thanks
I'm working with viscous dissipation as well. Could you give more info on your model and such. Also, can you tell me what papers you are referring to that have implemented this.
-BB
bhargavbharathan is offline   Reply With Quote
Old   June 8, 2016, 02:56
Alex Skerhut
Hey!
I am modelling Friction Stir Welding in ansys Fluent and according to several research papers the viscous term is multiplied by a factor of 0.01-0.1 since viscous dissipation depends upon atomic mixing which is not good in FSW. The papers I am referring to are:
1. Three-dimensional heat and material flow during friction stir welding
of mild steel
2. Thermal energy generation and distribution in friction stir welding
of aluminum alloys
If you get a solution to my problem, please let me know.
viscous coupling, viscous flow, viscous laminar, viscous resistance
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 04:09
Porous Modeling of Energy equation in OpenFOAM mohammad_kordo OpenFOAM Running, Solving & CFD 9 November 22, 2020 08:18
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
how to ad new energy equation to Fluent louiza FLUENT 0 May 21, 2010 09:39
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
