surface heat transfer coeff of wall flux
Old   June 1, 2016, 10:40
Default surface heat transfer coeff of wall flux
rsa
Reza
rsa is on a distinguished road
I have a case where the outer wall of the domain is in contact with the room temperature air. as a boundary condition for this wall I have only used convection where heat transfer coefficient is set to 200 and free stream T to 300 K. Then in the monitor section, I have defined the following monitor:
Report Type: Vertex Avg
Field Variable: Wall Fluxes -> Surface Heat Transfer Coef.
and I have plotted this against "Flow Time". I noticed two things:
1- the magnitude of the "Surface Heat Transfer Coef." is NEGATIVE all the time (the wall initial temperature is 1273 K)
2- the "Surface Heat Transfer Coef." is NOT constant!!! while as I said, in the boundary condition for this wall I have used a constant Heat Transfer Coefficient!
the negative value I imagine is due to the fact that the wall is loosing energy to free stream but can anyone tells me why the Surface Heat Tansfer Coef." monitor is not constant!!!
rsa is offline   Reply With Quote
heat flux, heat tranfer coefficient, heat transfer boundary, monitoring boundary
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
Heat flux and Heat transfer coefficient sakil2k3 FLUENT 4 July 5, 2015 16:07
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
surface heat transfer coeff. profile??? alp FLUENT 4 November 10, 2008 04:16
