Conjugate Heat Transfer transient
Old   June 1, 2016, 05:59
Default Conjugate Heat Transfer transient
Sara28 is on a distinguished road
Hello everybody,
currently iīm doing some litte examples to test some cases before i use it later in my simulations.
My case now is just a solid block with an energy source sourrounded by air.
First Question: ( i know very easy, but i struggle because some of my solutions arenīt right and maybe i have made mistakes here). If i want my solid do 2 Watt output, is it correct to say that my energy source is just 2 watt/volume block? I thought so!
My first simulation was with no flow just the air without moving und the second was with flow. Steady state
To check if i was right i looked at the fluxes --> total heat transfer rate at the walls of the solid. The net result was 2Watt. So thats right, isnīt it?
Then i tried a transient simulation with no flow. So the air was getting hotter. So far so good. But when i look now at the net result of the heat transfer i donīt get the 2 Watt.
So second Questin: Why is this so? Shouldnīt there be always 2Watt heat generation in my solid always? Do i miss something?
Please help me. Sorry if you think my questions are stupid, iīm still learning and i would kindly appreciate it if someone could explain to me
Sara28 is offline   Reply With Quote
conjugate heat transfer, energy source term, transient
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? rogbrito Main CFD Forum 1 February 19, 2019 03:11
conjugate heat transfer in a rotary condition rasekh64 FLUENT 4 June 19, 2013 04:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
