How to get lift distribution curve in fluent? |
May 31, 2016, 11:04 |
Rep Power: 10 |
Hi everyone, I am doing fluent analysis on an aircraft. Currently I trying to get the lift distribution curve along the wingspan. I have been trying to add an iso-surface at difference location of the wing and get the cp curve. Calculate the area under the graph give me the lift at that particular location. I am wondering if there is any other method to get the lift distribution along the wingspan directly? maybe create an iso-surface on the wing? Attached is my geometry together with its enclosure for your reference. Thanks.
May 31, 2016, 17:50 |
Rep Power: 18 |
Create a lift monitor via Solution > Monitors > Create > Lift... You can select which wall zones to include in this calculation (your wingspan may cover several wall zones).
Lift distribution | PB4 | STAR-CCM+ | 6 | May 31, 2016 10:46 |
How to obtain radial force distribution graph from FLUENT? | mrswordf1sh | FLUENT | 2 | March 29, 2016 11:04 |
Problem in temperature distribution in Ansys Fluent | ALI Riaz | FLUENT | 0 | March 6, 2016 14:05 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
calculating drag and lift in fluent | morteza08 | FLUENT | 4 | December 13, 2012 16:34 |
