May 27, 2016, 18:44 |
Divergence in model
Hi!
I am trying to simulated a gas stirred vessel (metallurgical ladle) using Eulerian multiphase model in 2D axisymmetric geometry. I´m using explicit scheme and dispersed turbulence model. The problem is that the solution diverges, showing an Courant number very high and also (sometimes) a flotating point error. I have used different mesh size using 7000, 12000, 17000, 24000, 50000, 100000 and 400000 elements, time step since 1e-05 to 1e-08 but the divergence still appears. What could be the cause? Please, if have any suggestions, I will apreciate it. The mesh is very fine in the simmetry axis and the interface of liquid. Thank you. |
axisymmetric, courant number, eulerian, fluent |
Coupling RPI wall boiling model with population balance model in Fluent | softice2006 | Fluent Multiphase | 1 | April 19, 2023 03:09 |
Divergence when using UDF for PVT Tait model | jpina | FLUENT | 0 | April 16, 2016 04:50 |
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" | musabai | OpenFOAM Running, Solving & CFD | 2 | February 20, 2015 15:07 |
Is it possible to model natural convection in a 2D horizontal model in fluent | caitoc | FLUENT | 1 | May 5, 2014 14:32 |
Turbine model - sudden divergence after stabilized residuals | Octagon | CFX | 3 | May 27, 2013 19:48 |
