species transport, two species with water prop's in micro channel, Solution Divergin |
Warangal, Telangana, India
Rep Power: 0 ![]() |
Can somebody assist me on this
I am using micro T channel for mixing two species. species A from one inlet and species B from other inlet. Both are having water properties. inlet diffusion is selected under species transport. steady laminar flow model is used. The solution is not converging for continuity for the above settings even when a residual of only 10^-03 is used for continuity. Thanks and regards, Manoj |
Multiphase flow with species transport | hassism | Fluent Multiphase | 0 | August 29, 2013 14:33 |
water channel flow with non symmetrical solution | bruce | OpenFOAM Running, Solving & CFD | 1 | October 21, 2011 12:00 |
species transport in water | lyn | FLUENT | 1 | December 12, 2007 18:15 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
