Need a help in fluent - diesel engine
Old   May 24, 2016, 05:02
Default Need a help in fluent - diesel engine
Mohamad Alashnawy is on a distinguished road
Dear all ,
Kindly can you help me in some of issues related to simulate combustion process in diesel engine with dynamic mesh ?
i use Ansys -Fluent (version 15) from about one year to make this simulation as a part from my study in master degree, but usually i don’t reach to my goals from this runs.
i made a run for motoring case and graph P- Theta and T-Theta for maximum pressure around 35 bar and Temperature about 1000 k. After that (this from around 6 months) i add injection before at around 340 Crank angle degree (CAD) which means before Top Dead Center (TDC) by 20 CAD and the surprise there is no any sudden change in pressure and temperature , almost you can say similar to motoring case in graph and values. By check temperature - fuel species distribution it appears un logic distribution, in addition to some errors usually appears with run such as divergence in AMG solver : Species or temperature .... etc.
Noteworthy i make change for almost all parameters in injection ( flowrate - injection speed - injection CAD duration - Injection Diameter - Inert or droplets ,,,etc.)
Realy i exhausted and fell very bad . Can any one help me in this issues, this help realy will chancge my life becouse there are alot of things paused till finish this master study
your fast responce is appreciated
Thanks
Mohamad Alashnawy is offline   Reply With Quote
Premixed heptane-air combustion in a diesel engine (HCCI-dieselEngineFoam) ayhan515 OpenFOAM Running, Solving & CFD 2 August 21, 2015 08:44
Using FLUENT in parallel using Oracle Sun Grid Engine peter.pan FLUENT 1 November 21, 2014 10:05
[ICEM] Tips for 3D tetra mesh quality for Fluent transient run. Rotary Engine Catthan ANSYS Meshing & Geometry 0 June 18, 2012 13:46
Engine modelling using fluent - advice nat2479 FLUENT 0 February 1, 2011 15:18
Can I use Fluent to stimulate diesel combustion Allanhill FLUENT 1 March 6, 2003 08:46
