can anyone please give me detailed answer about the purpose and change of y+ and y*
Old   May 18, 2016, 03:17
Default can anyone please give me detailed answer about the purpose and change of y+ and y*
sanjeev kumar.m
sanjiiv is on a distinguished road
Hi scholars,
please tell me whats the need and purpose of refining the mesh and changing the values of y+ in turbulence flow model.
what is the limits of y+ for general and different problems,and how to calculate the value of y+ for different problems based on flow models.
finally, what is the purpose of Y*
thank you ,
sanjiiv is offline   Reply With Quote
Old   May 19, 2016, 00:27
Lucky
y* and y+ are both inner variables but use slightly different velocity scales for the inner velocity.
Depending on the model, the near-wall turbulence models used need a certain y+ or y*. Hence, your mesh should be fine or coarse enough to meet that criteria. These criteria depend entirely on your models you select (whether explicitly or implicitly).
Old   May 24, 2016, 06:58
Sverige
rdajohansson is on a distinguished road
Y+ is calculated from the shear stress at the wall and can therefor be zero in some cases like stagnation and separation point. That's why there are a y* which is calculated from kinetic energy instead.
rdajohansson is offline   Reply With Quote
