May 12, 2016, 22:43 |
Fluent installation
Zeinab
Rep Power: 10 |
Hi there,
I'm fresh to fluent and trying to make a model of flow past a cylinder. I had some issues with installing the software (un-installed it once and installed it again) and, now, I have 2 versions of ANSYS (16 & 16.2) on my desktop. I was wondering if the incorrect/corrupted installation of the software could cause any issues when working with the software. For example, I am facing a weird problem with zooming into the mesh. When I zoom very close to the cylinder, I can not see the mesh elements and I need to zoom out to see the element. Thanks for your help Zeinab |
May 13, 2016, 23:01 |
Lucky
Rep Power: 66 |
Just make sure the latest version is the most recently installed version. i.e. makes you installed 16.2 after v16. If you installed v16 after you installed 16.2, then you should re-install v16.2
fluent, installation, zoom |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
Fluent 6.3 & Gambit 2.4 installation problem on OpenSuse 12.3 x86_64 | dfeid | FLUENT | 0 | September 26, 2013 07:52 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
