Crank angle for peak pressure value is not matching.. |
May 9, 2016, 14:59 |
Pawan Meena
Rep Power: 11 |
I am simulating the compression stroke of a Diesel Engine in Fluent. when I, got the results for Pressure-Crankangle curve (P-theta curve), the peak pressure value is matching with my experimental value but, the crank angle at which the peak occur is not matching. I am not getting, why the value of crank angle for peak value pressure are not matching. How to solve this problem?? |
November 23, 2016, 02:56 |
milad1
Hi
I want to plot P-crank angle in fluent How i can it? Tnx |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
Pressure value not matching to experimental result | Bisht | STAR-CCM+ | 10 | November 25, 2015 01:58 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 17:29 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 12:59 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 12:26 |
