May 3, 2016, 10:09 |
Use boundary condition type as parameter
Johan Hyrefeldt
Hi!
In my Fluent problem I have an inlet and outlet divided into different segments. The inlet consists of 6 adjacent faces, each with its own named selection, and therefore I can choose to close one inlet segment by changing the BC-type to "wall" instead of my other option "pressure-inlet". The same applies for the outlet segments and I can switch these between "pressure-outlet" and "wall". My problem is that I want to create a parameter for each inlet/outlet segment that can switch the BC-type between "wall" and "pressure-inlet/outlet". My idea is to run a DOE in workbench containing parameters for the BC-types and get results for different combinations of open/closed segments. Is there any way to create a parameter set with one parameter for each inlet segment and outlet segment where the values of the parameters are either "wall" or "pressure-inlet" respectively "pressure-outlet"? |
November 7, 2023, 11:00 |
Cla
Rep Power: 6 |
Hi Johan,
Did you eventually find a solution? I am currently trying to do the same thing. Thanks Claudia |
boudary types, boundary condition, design of experiment, parameter, parameter set |
Time step continuity error | lpz_michele | OpenFOAM Running, Solving & CFD | 0 | October 12, 2015 07:05 |
interFoam/kOmegaSST tank filling with printStackError/Mules | simpomann | OpenFOAM Running, Solving & CFD | 3 | February 17, 2014 18:06 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 18:08 |
Boundary condition setting for non-premixed combustion using reactingFoam | skyopener | OpenFOAM | 0 | May 23, 2010 23:55 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
