Applying boundary conditions for vertical rotating pipe. |
May 1, 2016, 11:04 |
pranay
Rep Power: 10 |
Hey guys,
I have a problem in setting boundary conditions for a problem,here is the problem. A rotating pipe is submersed in a two phase flow with second phase liquid is 0.02% volume fraction.Densities of both fluids is known,Rpm is 3000 for pipe.Interaction between faces is surface tension(0.024).20 mm of pipe is submersed.And working pressure is 0.624 bar.The pressure difference between oil level at bottom and outlet of pipe at top is zero. So I can't make fluid volume inside the bottom sump.I am able to give boundary conditions as pressure inlet at bottom of pipe and pressure outlet at top of pipe,but i can't give boundary conditions to oil at sump bottom since I can't create fluid volume.So please help me. Last edited by pranaychowdary; May 1, 2016 at 11:28. Reason: Additional information |
boundary conditions |
Boundary conditions of laminar flow in pipe | alireza.glz | OpenFOAM | 4 | May 27, 2019 06:03 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
rotating pipe flow wall boundary condition problem | preetam69 | FLUENT | 0 | October 8, 2013 12:16 |
Rotating Frame Boundary Conditions | gpavanb | FLUENT | 3 | July 19, 2013 04:13 |
