Turbulent model selection and mesh for cylinder-airfoil interaction |
April 28, 2016, 10:48 |
Nate Lau
Rep Power: 10 |
Hi, I want to investigate the interaction between an airfoil NACA0010 and upstream rod in air. Also there is a 0.1*chord distance in lateral direction. The point is to calculate the fluctuating force on airfoil.
Re of airfoil is set to be 6.85e4 and to cylinder it becomes 6.5e3. My question is which turbulent model should I take or the correct method is using laminar? Are there any mesh guide for this configuration. |
May 2, 2016, 05:15 |
Paritosh Vasava
Rep Power: 23 |
I recommend you go through this tutorial about simulating compressible flow over an airfoil.
airfoil, cfd, fluent, fsi, interaction |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[snappyHexMesh] How to Do External Mesh for Airfoil sHM | msuaeronautics | OpenFOAM Meshing & Mesh Conversion | 1 | September 23, 2012 04:00 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
