How to use UDF to get a grid cell centroid coordinates?
Old   April 27, 2016, 07:57
Default How to use UDF to get a grid cell centroid coordinates?
Lvan Lee
lvanlee is on a distinguished road
It was a simulation about mold electromagnetic stirring in continuous casting.
I worked out the lorentz force from Ansys Maxwell, now I want to add the lorentz force as source terms using the DEFINE_SOURCE macro.
So first, I need the cell centroid coordinates of the model mesh.
Then put the lorentz force on every coordinate as a momentum source.
So, how could I get the coordinates?
Thanks very much !
#include"udf.h"
FILE*fout;float xx[ND_ND];
DEFINE_ON_DEMAND(get_coords)
Domain *domain;
face_t f; cell_t c;Thread *t;
domain=Get_Domain(1);
t=Lookup_Thread(domain,2);
fout=fopen("faces.out","w");
if (fout==NULL)
Message("Can't open the file");
else
{ begin_c_loop(c,t)
{ F_CENTROID(xx,c,t);
fprintf(fout,"%d %g %g %g\n",c,xx[0],xx[1],xx[2]);
end_c_loop(c,t)
fprintf(fout,"\n");
fclose(fout);
this udf can't work out
lvanlee is offline   Reply With Quote
Old   April 27, 2016, 08:50
Lucky
F_CENTROID gives the face centers. C_CENTROID gives the cell centers.
Old   April 27, 2016, 10:54
Lvan Lee
Thank you. It was a mistake and I use the C_CENTROID actually. But when I interpreted the UDF, it shows the "line 28: function "CX_Message" not found (pc=55).“ But I just have 27 lines, no line 28 at all.
Old   January 3, 2021, 12:10
Krishna
kavatar is on a distinguished road
Could you please tell which solver did you use in Ansys Maxwell to calculate the Lorentz Force? Was it Eddy Current Solver or Magnetic Transient Solver?
And did this UDF worked to apply the Lorentz Force in Ansys Fluent.
I am also working on similar kind of Problem. Your comment would be of great help to me.
Thanks in advance !!
kavatar is offline   Reply With Quote
Old   December 20, 2021, 07:55
ssetay
ssetay is on a distinguished road
I'm doing similar work, has your problem been solved?
Can i ask some questions?
Thinks!
ssetay is offline   Reply With Quote
define_on_demand macro, fluent, udf
Setting cell variable values in a fluid zone using UDF eromon84 Fluent UDF and Scheme Programming 6 March 28, 2021 12:59
[OpenFOAM] View grid coordinates in Paraview ozzythewise ParaView 3 June 6, 2017 05:12
[OpenFOAM] Get cell center coordinates in a python script francois ParaView 2 June 3, 2017 09:20
I know the cell ID, how do I find the cell coordinates? simpomann OpenFOAM Programming & Development 6 June 30, 2014 11:29
Identifying cell in parallel UDF upeksa Fluent UDF and Scheme Programming 0 July 24, 2013 12:27
