High CL lift coefficient in Stall Angle of attack airfoil
Old   April 26, 2016, 21:27
Default High CL lift coefficient in Stall Angle of attack airfoil
Anggie Restue Saputra
restuesaputra is on a distinguished road
I did a flow simulation over airfoil NACA 0015 using ansys fluent. Everything is ok in values of CL and CD for AoA 0 degree till 10 degree. But when i did simulation in AoA 15 degree values of CL is very high arround 1, it should be the value of CL in this AoA is low arround 0.4 cause 15 degree is near the stall angle (due to experiment result).
Whats wrong with my simulation?
Thanks before
restuesaputra is offline   Reply With Quote
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
Lift Coefficient vs Angle of Attach for Pitching Airfoil fkanyako FLUENT 3 July 16, 2014 08:35
Lift Coefficient vs Angle of Attach for Pitching Airfoil fkanyako Fluent UDF and Scheme Programming 0 January 29, 2014 04:17
Analysis of angle of attack vs lift generated vikhattangady FLUENT 0 October 31, 2013 05:42
Lift Coefficient Vs. Angle of Attack cfd_pro Main CFD Forum 1 August 23, 2002 18:21
