How to plot any parameter against time for Transient simulation in Fluent? |
April 26, 2016, 08:59 |
Amit Chauhan
Rep Power: 16 |
I am simulating a problem of Turbulent jet flow in a mixing shell (cylindrical in shape). I need to monitor velocity on the jet axis. It is transient simulation and I run the case for flow time of 2 mins. I have already completed the simulation. I have saved .DAT file at regular time interval. Problem:- I need to plot velocity with respect to flow time on the jet axis. I do not find any such options available in Fluent. Someone please help in plotting this. Thank you in advance!!! |
April 26, 2016, 09:04 |
Jordi Pina
Rep Power: 11 |
What I do is to export the simulation into an Ensight file using the Calculation activities (I guess, I don't have Fluent right here) and using Paraview you extract all the information. You can do the same using CFD-Post of the ANSYS Workbench.
April 27, 2016, 01:07 |
#3 | |
Amit Chauhan
Rep Power: 16 |
Do we need to import all DAT files for this in ENSIGHT? How does it work with Paraview? I am using FLUENT 6.3.2. Is it possible to do something in this version of Fluent? |
April 27, 2016, 17:22 |
Lucky
Rep Power: 66 |
You can't plot anything vs time no matter what version of Fluent. Fluent is not a post-processor.
You need to export it into....something (CFD-post, excel, matlab, ensight, tecplot, something) Either export all the data files into a post-processor or If you know exactly what data you want and where you need it, then create a point/line/surface and export them using calculation activities (automatic data export). Then read these data files into your post-processor. First find or pick your favorite post-processor. Then you can ask specific questions. But learn how to import data for at least 1 time-step first. |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Unexpected deltaT decrease in pimpleFoam simulation | robyTKD | OpenFOAM Running, Solving & CFD | 9 | June 27, 2014 07:52 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
