April 19, 2016, 08:35 |
solar irradiation toward a target
Gabes
Rep Power: 10 |
Hello fluent users ,
I appreciate your time and effort to help others solve their problems . I work on radiation and convection modelling of a solar receiver for Concentrated Solar Power (CSP) tower systems with DO radiation model and i think i should use one of this solutions : 1- Model a solar irradiation source field by defining semi-transparent walls at the boundary of the computational domain. Each wall reflecting solar irradiation at a specific specular angle. By dividing a plane into many subsections, and assigning an irradiation direction to each that is pointed towards a specific target . 2- write UDF for gaussian distribution heat source with given maximum value as boundary condition on this semi-transparent wall and set the directions toward a target . 3 -( bailout plan less realistic ) set a uniform solar irradiation on a semi transparent wall and set directions toward a target i will be very grateful if you teach me how to apply one of this solution in order to solve this problem . Thank you |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 13:39 |
solar ray tracing and do irradiation | ericguangzhou | FLUENT | 2 | September 25, 2015 20:26 |
Solar Calculator | Dorasemon | FLUENT | 1 | July 25, 2013 10:20 |
