April 17, 2016, 17:42 |
Les turbulence model in steady mode
shahrbanoo
Rep Power: 13 |
Hi Dears
Is there any way to run a steady case with large eddy simulation turbulence model, ? Or better to ask is it possible? Best regards... |
April 18, 2016, 04:39 |
Cees Haringa
LES is inherently transient - you cannot run this in steady state. Good luck! Cees |
April 18, 2016, 12:00 |
#3 | |
Lucky
Rep Power: 66 |
LES is inherently a time-accurate simulation by definition. If you arbitrarily run it in steady mode, you will end up with a laminar flow because the fluctuations about the mean must average to the mean. |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 17:16 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
y+ for LES turbulence model | Pawan | FLUENT | 0 | December 7, 2007 01:40 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 05:34 |
