April 16, 2016, 04:50 |
Divergence when using UDF for PVT Tait model
Jordi Pina
Rep Power: 11 |
Dear all,
I'm modeling a polymer flow, whose density is temperature and pressure dependance and, moreover, has a discontinuity in the density in the melting point. The graphic looks like this: The UDF compiles and loads successfully and is the following: #include "udf.h" #include<string.h> #include<stdio.h> #include <math.h> #include <stddef.h> #include <stdlib.h> #include <nrutil.h> DEFINE_PROPERTY(cell_pvt2,cell,thread) { real T = C_T(cell, thread); real P = C_P(cell,thread); real B; real V; real V0; real rho; real B1s=8.54e-4; real B2s=1.59e-7; real B3s=2.99e8; real B4s=1.71e-3; real B1l=8.54e-4; real B2l=5.62e-7; real B3l=1.83e8; real B4l=3.99e-3; real Tg=144+273; if (T>Tg) { V0=B1l+B2l*(T-Tg); B=B3l*exp(-B4l*(T-Tg)); } else{ V0=B1s+B2s*(T-Tg); B=B3s*exp(-B4s*(T-Tg)); } V=V0*(1-0.0894*log(1+P/B)); rho=1/V; if (P > 0.0001) { return rho; } else{ return 1000; } } However, in the second iteration I give divergence problems and a floating point exception. I'm modeling the inlet of a polymer into a cavity filled with air, having a 0 atm outlet and a pressure inlet that pushes the polymer. I have tried the UDF without having the two regions but happens the same. I have tried different solvers and relaxing the UDF without success. Somebody has a hint? Thanks al ot! |
UDF for Multiphase euilerian model | pibea | FLUENT | 3 | April 30, 2024 02:25 |
EMMS drag model UDF | NAD | Fluent UDF and Scheme Programming | 26 | November 19, 2017 08:49 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 07:12 |
UDF fails to model 9.81m/s^2 gravity | jpo | Fluent UDF and Scheme Programming | 2 | January 24, 2012 19:15 |
UDF of Zimont model in fluent | Z | Main CFD Forum | 0 | February 17, 2005 04:07 |
