Saving point cloud in Fluent
Old   April 14, 2016, 12:13
Default Saving point cloud in Fluent
Alessandro
a_soli is on a distinguished road
Hi everybody,
I know that this topic has been covered in previous posts, and I have gathered some useful information from them, but now I am kind of stuck on my problem. I am a new user of Fluent, so I am not sure if this is the correct approach to follow.
I am running a transient simulation over a complex geometry and I would like to export a confined set of points each time step for post-processing in tecplot. I have produced a matlab script that defines the points to export and generates a file journal that makes fluent define those points (as point-surface) and set up an automatic export case. (I have no experience in UDFs, so I haven't investigated the possibility of using them)
However, even by grouping those points, I would get a tecplot export like:
HEADER (title, variables) ORDERED ZONE RECORD (ZONE = "node_1"....)
DATA FOR NODE 1
1 (I guess it's the connettivity matrix for one single node)
ORDERED ZONE RECORD (ZONE = "node_2"....)
DATA FOR NODE 2
1 (I guess it's the connettivity matrix for one single node) (...)
receiving a tecplot error. I would like something like:
ORDERED ZONE RECORD (ZONE = "zone"....)
DATA
Is it possible to create a zone with all the points so to eliminate the problem I mentioned? Is there any smarter approach to what I want to achieve?
Thanks in advance
a_soli is offline   Reply With Quote
fluent, point cloud, tecplot
Floating point exception during parallel mode of fluent aamer FLUENT 10 May 16, 2019 10:49
How to change boundary conditions by judging the temperature of one point in fluent? hotin87 Fluent UDF and Scheme Programming 16 September 25, 2015 04:01
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
