Analysis of rotating fan in room in ansys fluent
Old   April 10, 2016, 15:01
Default Analysis of rotating fan in room in ansys fluent
harianshu is on a distinguished road
Hello !
I am willing to analyze fan rotation in fluent for converged solution in transient manner until it is statistically steady so that i can apply ffowcs williams hawking's model to find the noise created by fan blades(aerodynamically generated noise).I have studied that Moving Reference Frame and Sliding mesh
are methods for such kind of analysis. Would someone please explain me the theory behind these methods?
I have an manual suggesting to first use M.R.F for steady analysis and then use sliding mesh method for transient analysis by feed the solution of steady analysis to this and changing some set up conditions.Is it a right way to do this ? Is having steady analysis before transient in this case is important?
It would be quite helpful if someone help me with the boundary conditions also.
Thanking you in anticipation.
harianshu is offline   Reply With Quote
fan aerodynamic, fan analysis, fluent, rotary parts, rotary wing/blade
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Fluent analysis of heat source in a room vishnu_240 FLUENT 5 September 13, 2014 10:15
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 16:30
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 18:06
