April 5, 2016, 03:48 |
Low Re flow past cylinders in tandem
Sagar
Rep Power: 10 |
Hello all
I am trying to simulate a low Re (Re=100) flow past two cylinders in tandem and I am unable to get vortex shedding which is quite obvious and also reported in literature. When I tried ANSYS Mesh unstructured mesh I was able to get proper results, but when I tried to make a structured mesh with ICEM CFD, I am unable to reproduce proper results. I must say that I am a newbie in ICEM and I have a hunch that my meshing is not proper. So I am attaching the image of my mesh. Kidnly suggest how to go about it. Regards |
April 5, 2016, 10:16 |
#2 | |
Create ogrid around both circles and run the solution. |
April 5, 2016, 10:29 |
#3 | |
Sagar
Rep Power: 10 |
I knew mesh was the culprit. However, I am not able to figure out how to create O grid meshing around 2 circles. I was able to do it successfully for a single circle. With 2 circles, when I try to split block around small circle, it intercepts with the larger circle. Kindly suggest any tutorials where I can learn about blocking for these kind of geometries. Regards |
April 5, 2016, 15:18 |
Sagar
Rep Power: 10 |
Smaller cylinder is upstream and the gap between them is 1.2 times the diameter of the bigger cylinder.
April 5, 2016, 18:00 |
Sagar
Rep Power: 10 |
In the mean time I tried creating two separate O grid blocks around 2 circles and it looks like this. I'm pretty sure it is not correct. Could you kindly suggest what changes I could make?
April 10, 2016, 18:59 |
Sagar
Rep Power: 10 |
FLUENT LES Simulation of flow past a cube | NGH | FLUENT | 6 | November 14, 2012 00:45 |
About compressible flow at low mach | hit | Main CFD Forum | 2 | October 26, 2009 22:21 |
low speed compressible flow | lily | CFX | 2 | November 16, 2005 06:15 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 08:59 |
beginning - Flow past a square cylinders | Odenir de Almeida | Main CFD Forum | 4 | February 10, 1999 10:38 |
