April 4, 2016, 03:01 |
Premixed combustion in micro-combustor
Pradip
Rep Power: 11 |
I am trying to simulate premixed combustion in steel micro-combustor with dimensions 18mm X 8mm X 3mm with thickness 0.5mm outside. I have applied premixed combustion model with non-adiabatic condition. For mesh interfaces I have created interface with 'coupled wall' and 'matching' option. In materials I have created methane-air mixture with its properties at equivalence ratio 1 and temp. 300K. In boundary conditions I have given inlet velocity (0.5 m/s), and for specification method I have used turbulence intensity as 5% and hydraulic diameter for inlet and pressure-outlet with same specification method. For wall option I have used shell conduction. I am trying to simulate this mixture but it is not burning though solution is converging. I have tried different solution schemes and changed specification methods but in vain. Since I am taking these conditions from one of the journals that mixture must be burning mixture. So here I am wrong somewhere. Is there anyone who have tried this or who can point what is wrong in this. I am hoping that someone will guide me or point out my errors. Thank you so much in advance |
coupled wall, interface, mixture not burning, premixed combustion |
Modelling of premixed combustion in a burner rig | ThomasS | FLUENT | 12 | September 7, 2018 13:07 |
Premixed combustion in a combustor with a CD nozzle | Subrat@cgpl | FLUENT | 0 | March 29, 2016 05:02 |
How to model premixed combustion using partially premixed combustion model in Fluent? | sab10012 | FLUENT | 0 | October 6, 2015 01:18 |
Premixed combustion model - help! | HeKhalil | ANSYS | 0 | November 22, 2012 05:39 |
Partially Premixed Combustion - Direct Fired Boiler | oknus | FLUENT | 0 | April 10, 2012 10:52 |
