Wind Turbine Simulation
Old   April 2, 2016, 17:27
Default Wind Turbine Simulation
Hammad Iftikhar
hammad0252 is on a distinguished road
Hi, I am working on wind turbine simulation using a rotating reference frame. My aim is to calculate the power generated by the designed turbine. Here is what I have so far.
I have created a fluid domain with the rotor in the middle and a cylinder to simulate the rotating domain. Right now the rotor is subtracted from the domain while the cylinder is whole.
My first question is whether it is fine the way I have it currently configured or should it be some other combination?
Should I subtract the cylinder from the fluid domain and then the rotor from the cylinder?
Any help would be appreciated, Thank You.
hammad0252 is offline   Reply With Quote
Old   April 3, 2016, 09:22
Cees Haringa
CeesH is on a distinguished road
Looks fine, you can indeed subtract the rotor from the cylinder. The cylinder and bulk domain should be separate bodies that do not overlap; is that currently the case?
CeesH is offline   Reply With Quote
Old   April 3, 2016, 13:16
Hammad Iftikhar
Currently they overlap as I wasn't sure. I will fix that.
Furthermore as I understand to calculate power I will multiply the rotational velocity given to the moving frame with the torque that is felt on the rotor. Is that correct?
Old   April 3, 2016, 15:25
Cees Haringa
Ok, if you subtract the cylinder from the box, and keep the cylindrical body with the rotor, all should be fine.
You can calculate the torque using reports > forces and then select moments, setting the right axis origin and direction, and then calculate the torque on the turbine indeed. After that, indeed multiply by the 2*pi*N (rps), and you have the power.
Good luck! Cees
Old   April 4, 2016, 13:15
Hammad Iftikhar
Just an update. I made the mesh shown below, used sphere of influence in body sizing so that most of the elements are in the middle.
I feel that the elements might not enough but considering the computer I have access to currently this is the best I can do. I hope to make a finer mesh once I have access to a more powerful computer.
In fluent I set the time to transient, k-w SST for turbulence, frame motion to the cylinder about x-axis at 37.5 rad/s. Inlet velocity set to 5 m/s and pressure outlet. Set the flow time to 5s with 50 intervals each 0.1s. The solution is being calculated as we speak. Hope it works out.
Old   April 4, 2016, 13:33
Cees Haringa
why is there a very dense mesh region far away from the cylinder? I understand you are limited in the mesh size, so it seems to me it is important to be efficient in refinement - that clump of cells on the upper right does not look very efficient to me. Maybe you can improve the mesh, making sure:
1) the mesh is fine close the the blades, and cruder far away
2) the domain is predominantly filled with hexahedral/polyhedral elements (hexahedral will be though/impossible near the impeller, but surely applicable to the bulk of the domain)
Old   April 7, 2016, 09:33
Hammad Iftikhar
I changed the mesh to be a bit more concentrated around the cylinder.
A view of the new mesh
Sliced View Along the XZ Plane
Sliced View Along the YZ Plane
Afterwards I ran the calculations and it came with the following moment report.
But according to this the turbine would generate only 0.090707897*37.5 = 3.40 W
Power available = 0.5*3.1415*(0.4^2)*(5^3)*1.225 ( 1/2 * pi * r^2 * v^3 * rho) = 38.48
Which would correspond to a coefficient of performance of 8.839% which seems quite low. Is this right considering the blade shape and the small size and speed or am I doing something wrong?
Old   April 7, 2016, 17:41
Hammad Iftikhar
Looking at the results in CFD-Post I think I might have screwed up the mesh interfacing. I am going to try again this time interfacing each face individually.
Old   March 5, 2018, 05:09
Default Similar Problem
Payar Radfar
PayarRadfar is on a distinguished road
I am doing my final year project (Mechanical engineering, be Hons) on ducted wind tubines. I am mainly interested in increasing the power generation (obviously). I have got also some data from an actual turbine built by a company;such as power generated at each wind speed in the venturi.
I managed to run a cfd model on this and got pretty close results to what the company achieved. Using their data (power generated and power coefficient) and my cfd results, I managed to find the pressure difference caused by the turbine.
The study is a 2d study at first which later on i will be doing also a 3d and instead of the turbine i set a porous region.
My question is even if i do get this right, and lets say i change geometry or some other stuff to increase the mass flow rate, how can I know the new pressure difference caused by the turbine? Because, Based on what I think, turbines would obviously give different pressure difference at different rotational speed (that is how it generates different power at different speed).
Pretty much, I am interested to say that the power generated is increased by certain percentage etc.
Any guides ?
PayarRadfar is offline   Reply With Quote
Old   October 17, 2018, 13:02
M. Oki Nugraha Lubis
okinugraha is on a distinguished road
hammar, why the fluid not flow indeed rotating body or blade ?
okinugraha is offline   Reply With Quote
fluent, power, wind turbine
wind turbine blade flow simulation rsskarthikeyan FLUENT 0 May 27, 2015 06:40
Torque of wind turbine simulation caohan FLUENT 8 August 12, 2014 00:01
Simulation of fan Vs wind turbine mohammad Main CFD Forum 0 November 5, 2013 09:43
wind turbine simulation, Ansys Post results question Laions CFX 7 September 20, 2011 06:13
3D simulation of wind turbine in Yaw wind(in a lateral wind) mohammad Main CFD Forum 0 December 28, 2010 04:26
