solver settings
Old   April 2, 2016, 03:30
Unhappy solver settings
ajay varma
ajayvarma5 is on a distinguished road
iam doing 2D analyses on a wing in fluent. ive done modeling in icem took square doman of 10x10 , i have given a mesh of 16L in fluent im using 2414 aerofoil, velocity 30 m/s, Re number is 2e+6,
im using velocity inlet and pressure outlet as boundary conditons, remaining are walls even curve of the aerofoil , ive used
turbulence models: k-w SST
solver settings: coupled, lease squared and second order upwind equation
although solution are converging around 80 iterations im getting very low CL and CD values.
i think i have created a good quality mesh in icem ,( premesh quality
determinant was 1 , and aspect ratio was also below 50 ) where am i going wrong pls help me im new to fluent
ajayvarma5 is offline   Reply With Quote
#fluent, #icem #subsonic
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver malicemethods FLUENT 3 May 25, 2018 15:25
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 08:45
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
HP Turbine Flow simulation Solver settings Puneet FLUENT 1 August 10, 2003 06:00
