April 1, 2016, 15:39 |
S-duct simulation
Hello everyone!!
I am trying to solve an S-shaped duct which I designed, it is a kind a airial target (not real plane, just model) And I have a trouble to simulate outgoing flow, as a boundary condition of calculating domene is a pressure-farfield in shape of ball with diameter 10 times bigger than the bigest dimension of the plane. and tha face of engine from where I want to tate out the air is as pressure-outlet there is defined target mass flow 1.888 kg/s and pressure 101325 Pa. I want to simulate and obtain pressure loos in whole range of possible flying condition including staic condition (airplane is steady and engine is running) in my first case the pressure-farfield was set up on M=0 and pressure 1013 temperature 101325. and immediately like I started computing it was diverting or some warnings was plotted. I am really desperate I will try conect a picture latter |
April 1, 2016, 16:32 |
here it is:
on picture we can see plane with duct yellow is like wall, blue is pressure outlet, and red is pressure-farfield, no else boundary condition are used. Picture is simple there missing some surfaces as a other half and also the tip of airplane and the end of airplane |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 11:15 |
Use homogeneous results as the initial guess for an inhomogeneous simulation | JuPa | CFX | 5 | December 26, 2014 14:44 |
Flow coming from Industrial radial fan simulation in duct | crixman | OpenFOAM Running, Solving & CFD | 2 | November 10, 2014 05:05 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
Fan simulation with inlet and outlet duct for finding fan curve | chaudhry_hashim | FLUENT | 0 | August 6, 2014 11:49 |
