Problem
Old   March 31, 2016, 22:05
Default Problem
Helio Jose Alipio Junior
heliojjr is on a distinguished road
i am a undergraduated student, and i am really new at the ansys fluent.
i tried to run an analysis, and when i update the project the follow error hapens, Unable to update solution. Number of iterations should be greater than zero.
someone can help me with that?
heliojjr is offline   Reply With Quote
Old   April 1, 2016, 03:33
Cees Haringa
CeesH is on a distinguished road
well, if you set the number of iterations to 0, nothing will be calculated. So you have to set it greater than zero in order for something to happen... (under the run calculation tab)
CeesH is offline   Reply With Quote
Old   April 1, 2016, 16:35
ok thanks, but i did not found where i can set the number of interactions on ansys workbench 16,0
Old   April 1, 2016, 17:19
Cees Haringa
Like I said in my previous post, you will find in under solution > run calculation. You may be better of to take some basic tutorials in Ansys, however. Maybe try the tutorials by Cornell University - they are very easily found on google.
Old   April 1, 2016, 17:24
thanks, now i found it, yes that is my first time using the software is for an academic assignment, i will look for the cornell tutorials, thanks any way
Old   April 2, 2016, 00:51
Lucky
If you are very new, I recommend to launch Fluent directly (without using workbench) and do some Fluent tutorials before switching over to workbench (if you even need it).
car, update failed
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
