Reverse flow at the outlet
Old   March 30, 2016, 05:31
Default Reverse flow at the outlet
muhamed
Mohammad80 is on a distinguished road
Hi.
I have a problem with the reverse flow at the outlet of my geometry. I am doing a simulation to determine the water drag force on a pier inside a channel using FLUENT. I want to get the results for a Laminar flow (v=0.0001 m/sec). the simulation is going well but the drag force I got is negative, that means the reverse flow affecting on the results. I increased the elements density and I changed the geometry to be as shown in the attached picture and made the outlet far from the pier and I decreased the time step size but I still get the reverse flow warning messages. I read all the comments in this site about this problem and i did all what were suggested but unfortunately, the problem stills unsolved. Any tips please?
Mohammad80 is offline   Reply With Quote
backflow, negative drag force, reverse flow
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Temperature at a velocity/mass flow outlet saisanthoshm88 CFX 1 July 8, 2014 19:35
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! XIAOYI LI FLUENT 11 September 14, 2012 17:43
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 10:38
