negative cell volume detected while running ANSYS Fluent UDF |
March 27, 2016, 23:45 |
Rep Power: 10 |
I am trying to simulate vortex induced vibrations past a 2D cylinder using ANSYS Fluent. I am new to dynamic meshing, I activated the 6 degrees of freedom solver along with smoothing and re-meshing. I keep getting the error saying negative cell volume detected. I tried reducing the time step and increasing the stiffness, it still shows the same error. Could someone please help me with this problem. I appreciate your time. Thank you |
dynamic mesh, fluent - udf, mesh 2d, udf and programming |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Negative cell volume problem in-cylinder | ziani.lotfi | FLUENT | 0 | April 11, 2012 08:54 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
